Amplifier
20.12.2004 12.41.17 #1 av 3
Postet av: petulant
Jeg har fått tak i en Hitachi HA-2500 amplifier. Er det noen som vet noe om denne modellen?(Er trolig fra 70-80 tallet).
Alt av info. om denne modellen er ønskelig.
Petulant..
07.01.2005 23.11.08 #2 av 3
Postet av: music_junkie
Fant dette på nettet, håper det jeg hjelper deg.
Tungt stoff, orka ikke oversette eller no sånt.. sorry.. for sent for meg til sånt :lol: :wink:
HA-2500/883
Precision High Slew Rate Operational Amplifier
Description
HA-2500/883 is a monolithic operational amplifier which is optimized to deliver excellent slew rate, bandwidth, and settling time specifications. The outstanding dynamic features of this internally compensated device are complemented with low offset voltage and offset current. This dielectrically isolated amplifier is ideally suited for applications such as data acquisition, RF, video, and pulse conditioning circuits. Guaranteed slew rates of ±25V/µs minimum make it an excellent component in fast, accurate data acquisition and pulse amplification designs. To insure compliance, all devices are 100% tested for AC performance characteristics over the full temperature limits. A typical 12MHz gain bandwidth product and 500kHz full power bandwidth make this device well suited to RF and video applications. With guaranteed offset voltages of 5mV plus external offset adjust flexibility and low offset current, this amplifier is particularly useful in signal conditioning d e s i g ns .
April 2002
Features
· This Circuit is Processed in Accordance to MIL-STD883 and is Fully Conformant Under the Provisions of Paragraph 1.2.1. · High Slew Rate . . . . . . . . . . . . . . . . . . . . . . .25V/µs (Min) 30V/µs (Typ) · Wide Power Bandwidth . . . . . . . . . . . . . . . 350kHz (Min) · High Input Impedance . . . . . . . . . . . . . . . . . 25M (Min) 50M (Typ) · Low Offset Current . . . . . . . . . . . . . . . . . . . 25nA (Max) 10nA (Typ) · Low Quiescent Current . . . . . . . . . . . . . . . . . 6mA (Max) · Fast Settling Time (0.1% of 10V Step) . . . . 330ns (Typ) · High Gain Bandwidth Product . . . . . . . . . 12MHz (Typ) · Internally Compensated For Unity Gain Stability
Applications
· Data Acquisition Systems · RF Amplifiers · Video Amplifiers · Signal Generators · Pulse Amplification
Ordering Information
PART NUMBER HA2-2500/883 TEMP. RANGE (oC) -55 to 125 P ACKAGE 8 Pin Can PKG. NO. T8.C
Pinout
HA-2500/ 883 (METAL CAN) TOP VIEW
COMP 8 BAL 1 + 3 4 V5 7 V+
-IN
2
6 O UT
+IN
BAL
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures. 1-888-INTERSIL or 321-724-7143 | Intersil (and design) is a registered trademark of Intersil Americas Inc. Copyright © Intersil Americas Inc. 2002. All Rights Reserved 1
Spec Number
511002-883 FN3734.2
HA-2500/883
Absolute Maximum Ratings
Voltage Between V+ and V- Terminals . . . . . . . . . . . . . . . . . . . 40V Differential Input Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15V Voltage at Either Input Terminal . . . . . . . . . . . . . . . . . . . . . . V+ to VPeak Output Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 50mA ESD Rating. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . <2000V
Thermal Information
Thermal Resistance (Typical, Note 1) Metal Can Package . . . . . . . . . . . . . . . . . 160oC/W 75oC/W Package Power Dissipation Limit at 75oC for TJ 175oC Metal Can Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 625mW Package Power Dissipation Derating Factor Above 75oC Metal Can Package . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.3mW/oC Maximum Junction Temperature. . . . . . . . . . . . . . . . . . . . . . . 175oC Maximum Storage Temperature Range . . . . . . . . . . -65oC to 150oC Maximum Lead Temperature (Soldering 10s). . . . . . . . . . . . . 300oC JA JC
Operating Conditions
Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC Supply Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±15V VINCM 1/2 (V+ - V-) RL 2k
CAUTION: Stresses above those listed in "Absolute Maximum Ratings" may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTE: 1. JA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief
TB379 for details.
TABLE 1. DC ELECTRICAL PERFORMANCE CHARACTERISTICS Device Tested at: VSUPPLY = ±15V, RSOURCE = 100 , RLOAD = 500k, VOUT = 0V, Unless Otherwise Specified. PARAMETER Input Offset Voltage Input Bias Current SYMBOL V IO VCM = 0V CONDITIONS GROUP A SUBGROUPS 1 2, 3 +I B VCM = 0V, +RS = 100k, -RS = 100 1 2, 3 -IB VCM = 0V, +RS = 100, -RS = 100k 1 2, 3 Input Offset Current Common Mode Range I IO VCM = 0V,+RS = 100k, -RS = 100k 1 2, 3 + C MR V+ = 5V, V- = -25V 1 2, 3 -C M R V+ = 25V, V- = -5V 1 2, 3 Large Signal Voltage Gain +AVOL VOUT = 0V and +10V, RL = 2k 4 5, 6 -AVOL VOUT = 0V and -10V, RL = 2k 4 5, 6 Common Mode Rejection Ratio +CM RR VCM = +10V, V+ = +5V, V- = -25V, VOUT = -10V VCM = -10V, V+ = +25V, V- = -5V, VOUT = +10V 1 2, 3 1 2, 3 TEMP (oC) 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 MIN -5 -8 - 200 - 400 - 200 - 400 -2 5 -5 0 +10 + 10 20 15 20 15 80 80 80 80 MA X 5 8 200 400 200 400 25 50 -1 0 -10 UNITS mV mV nA nA nA nA nA nA V V V V kV/V kV/V kV/V kV/V dB dB dB dB
-CM R R
Spec Number 2
511002-883
HA-2500/883
TABLE 1. DC ELECTRICAL PERFORMANCE CHARACTERISTICS (Continued) Device Tested at: VSUPPLY = ±15V, RSOURCE = 100 , RLOAD = 500k, VOUT = 0V, Unless Otherwise Specified. PARAMETER Output Voltage Swing SYMBOL +VOUT RL = 2k CONDITIONS GROUP A SUBGROUPS 4 5, 6 -VOUT RL = 2k 4 5, 6 Output Current +IOUT VOUT = -10V 4 5, 6 -IOUT VOUT = +10V 4 5, 6 Quiescent Power Supply Current +ICC VOUT = 0V, IOUT = 0mA 1 2, 3 -ICC VOUT = 0V, IOUT = 0mA 1 2, 3 Power Supply Rejection Ratio +PSRR VSUP = 10V, V+ = +20V, V- = -15V, V+ = +10V, V- = -15V VSUP = 10V, V+ = +15V, V- = -20V, V+ = +15V, V- = -10V N ot e 2 1 2, 3 1 2, 3 1 2, 3 -VIOAdj N ot e 2 1 2, 3 NOTE: 2. Offset adjustment range is [VIO (Measured) ±1mV] minimum referred to output. This test is for functionality only to assure adjustment through 0V. TABLE 2. ECTRICAL PERFORMANCE CHARACTERISTICS Device Tested at: VSUPPLY = ±15V, RSOURCE = 50, RLOAD = 2k, CLOAD = 50pF, AVCL = +1V/V, Unless Otherwise Specified. PARAMETER Slew Rate SYMBOL +SR CONDITIONS VOUT = -5V to +5V, 25% +SR 75% GROUP A SUBGROUPS 7 8A, 8B -SR VOUT = +5V to -5V, 75% -SR 25% 7 8A, 8B TEMP (oC) 25 125, -55 25 125, -55 MI N 25 20 25 20 MA X UNITS V/ µs V/ µs V/ µs V/ µs TEMP (oC) 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 25 125, -55 MIN 10 10 10 7.5 -6 -6 . 5 80 80 80 80 VIO-1 VIO-1 VIO+1 VIO+1 MA X -1 0 -10 -10 -7.5 6 6. 5 UNITS V V V V mA mA mA mA mA mA mA mA dB dB dB dB mV mV mV mV
-P SRR
Offset Voltage Adjustment
+VIOAdj
Spec Number 3
511002-883
07.01.2005 23.40.37 #3 av 3
Postet av: petulant
takker og bukker..
